592,217 active members*
5,550 visitors online*
IndustryArena Forum > Machinery Manual, Brochure / Photo Archives > Machinery Manuals / Brochures > We need documentation for early 1990's M3X retrofit controller for a Bridgeport knee
    Feb 2021
    I am looking for the original setup documentation for a retrofit Bridgeport knee mill controller as sold by CNC Automation Inc.. It is an early 90's era machine, a DOS based system running on a 486 based board. It is the version 1 of the controller board they used.
    Specifically I am looking for the documentation on how to set the values in the OEM file/setup screen.
    My friend was talked into buying such a unit and didn't know at the time that it should have had its documentation with it. A subsequent crash caused it to lose its values.
    The folks at CNCAUTO have been extremely helpful in trying to help BUT is is 30 years old and they are trying to play Indiana Jones and dig through ancient artifacts. They were able to
    provide the files/components that I needed to get the system fully functioning, but now I need to know how to set it up.
    Thanks !
    Dave
    Mar 2006
    35
    Re: We need documentation for early 1990's M3X retrofit controller for a Bridgeport k
    I know this is an old thread, but I thought I would post this here in case it helps anyone.
    Mar 2006
    35
    Found 1 more, the programming manual, file was too large so I split in 4 sections
  1. Early FADAL VMC retrofit
    By dkyuss in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2016, 03:38 PM
  2. Early 90's Fanuc System Retrofit - Spindle Issues
    By sousanator in forum Servo Motors / Drives
    Last Post: 04-25-2016, 10:50 PM
  3. Early 1900's Rockford Horiz./Vert. Mill cncpc-retrofit
    By GM1G in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2011, 07:08 PM
  4. Manuals needed for early model Bridgeport EZ-Trak
    By jat in forum Bridgeport / Hardinge Mills
    Last Post: 07-31-2010, 04:10 PM
  5. early bridgeport cnc error CODE HELP
    By endmill1 in forum Bridgeport / Hardinge Mills
    Last Post: 02-24-2009, 07:05 AM
