504,179 active members
6,045 visitors online
Thread: weak drill?
    Junior Member
    Nov 2018
    weak drill?
    My drilling machine after a period of using the feeling it is not healthy. The speed is also much reduced. So why?
    Feb 2019
    13
    You need to repair your machine or at least clean it from both inside and outside. Sometimes with regular use, wear and tear machine get weaker. You can also lubricate part if needed!
    Jul 2019
    Do you want to choose the good quality Clamping Kits for milling machines and drill presses? If yes, the raycofixture offer a huge range of clamping kits at a reasonable price only for you. We have different items R8-CK-A, R8-CK-B, and R8-CK-C with different thread size. To more, must follow the website http://www.raycofixture.com
