585,722 active members*
4,607 visitors online*
    Weeke help and info
    This forum looks like it has all kinds of good technical info across many different platforms. The shop I work in has 3 Weekes. One 550 from about 2000 and two 350 form 2004. I have done a little searching, but I can't find what I'm looking for.
    Is there a Weeke specific area for searching and posting?
    I would like to use DNC on the 550. Is there any info on how to set this up?
    Sent from my SM-A136U using Tapatalk
    Re: Weeke help and info
    Here is a little more info.
    Machine: Weeke optimal backup 550 produced in 2002
    Currently use Homatic IPC to send programs to the controller.
    The controller is a NUM 1040C series II
    We build our programs primarily using WoidWOP 4.5 (Build 590)
    Please let me know if you need other information.
  1. Help??? Weeke Vantage 33
    By EugenijusPro in forum CNC Machining Centers
    Last Post: 01-14-2021, 07:29 PM
  2. Weeke BP 120 and Weeke 2000-IPC Win98 PC Crashed
    By glenn_wood in forum CNC Machining Centers
    Last Post: 01-04-2020, 10:34 PM
  3. Weeke BP 150 and Weeke BHC 350 Referencing In X Axis Problem
    By bedslouki in forum CNC Machining Centers
    Last Post: 03-01-2018, 11:52 AM
  4. Weeke
    By Somerset CNC in forum Commercial CNC Wood Routers
    Last Post: 12-06-2010, 08:30 PM
