585,880 active members*
5,950 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > WEG CFW300 VFD + KL-800 water cooled spindle settings
    Dec 2017
    13
    VFD: WEG CFW300A06P0S1NB20
    120V single phase in, 220V three phase out, 1.5HP
    https://www.automationdirect.com/adc...300a06p0s1nb20
    Manuals: https://cdn.automationdirect.com/sta...wegdrives.html
    Spindle: KL-800
    220V, 5A, 400Hz, 8000-24000RPM, 0.8kW water cooled
    https://www.automationtechnologiesin...illing-spindle
    Current settings:
    P100 (Acceleration): 2 seconds
    P101 (Deceleration): 2 seconds
    P133 (Drive Min speed): 133 Hz
    P134 (Drive Max speed): 400 Hz
    P156 (Rated Speed Overload Current): 5.5A
    P157 (50% Speed Overload Current): 5.5A
    P158 (20% Speed Overload Current): 5.5A
    P223 (Direction): 1 (forward)
    P400 (Motor Rated voltage): 220 V
    P401 (Motor rated current): 5A
    P402 (Motor rated speed): 24,000 RPM
    P403 (Motor rated freq.): 400 Hz
    When drive is enabled, motor turns at very slow rate of speed (~550-600 RPM) and immediately throws an A046 (motor overload alarm) and if you let it continue to run it will throw a F072 (motor overload fault) after about 30 seconds.
    Video of spindle run: https://drive.google.com/file/d/1MDO...ew?usp=sharing
    The most likely issue seems to be incorrect settings in the VFD... but it could be a spindle issue, or ?
    Help, thoughts, anything is much appreciated.
    Dec 2017
    13
    Re: WEG CFW300 VFD + KL-800 water cooled spindle settings
    Problem solved...
    Setting max voltage and frequency sets the 100% point on the V/f curve - but doesn't adjust any of the other points.
    50% voltage at 30Hz, and 100% voltage at 60Hz will definitely cause overload.
    Set
    P145 (Field Weakening frequency): 400 Hz
    P146 (Intermediate frequency): 200 Hz
    ...and everything appears to be working well.
  1. 2.2KW Water-cooled Spindle and VFD
    By shisa7807 in forum Want To Buy...Need help!
    Last Post: 04-11-2019, 02:10 PM
  2. 2.2kw water cooled spindle VFD wiring
    By Hyperryd in forum DIY CNC Router Table Machines
    Last Post: 03-30-2018, 03:21 PM
  3. 2.2 Kw Water Cooled spindle with GS2 VFD Package New
    By sharbold in forum For Sale Only
    Last Post: 06-23-2015, 10:09 PM
  4. VFD/Water Cooled Spindle Help
    By Jerseydog in forum Spindles / VFD
    Last Post: 05-02-2015, 02:54 PM
  5. Water cooled spindle 2.2kW settings
    By lolos1979 in forum DIY CNC Router Table Machines
    Last Post: 08-27-2010, 07:23 PM
