585,930 active members*
3,649 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Wet cutting foam to prevent dust
Results 1 to 5 of 5
    Nov 2005
    80
    I am planning to do some foam cutting.
    I want to prevent the fine dust. Larger chips are fine.
    I am planning to finish rough edges by hand so I don't need very smooth cuts.
    I was wondering if I can spray the foam with water to prevent fine dust.
    I am also thinking of Cutting with a thin bit, using low rpm high travel speed. I also am planning to cut instead of carving a large vloume.
    Any ideas ?
    thanks
    Apr 2004
    5737
    Re: Wet cutting foam to prevent dust
    Let us know how it goes, okay? I'm assuming you've got flood cooling set up on your machine, right? And it's all rust-proof, with no parts like MDF spoilboards that are going to be damaged by water. Are you using straight water, or lubricant "milk"? Dry foam dust definitely does make a mess what with static cling and all - I'm curious as to how much difference water will make.
    Andrew Werby
    Website
    Nov 2005
    80
    Quote Originally Posted by awerby View Post
    lol calm down.
    I am planning just to mist the surface so that it prevents fine dust from going airborne.
    I don't think that much humidity will cause any rust given that I am running the machine in warm environment and it is mostly aluminum anyways.
    Dec 2003
    1222
    What will the foam be used for after machining?If its any form of composite work,moisture will be unwanted.
    Nov 2005
    80
    Quote Originally Posted by routalot View Post
    I am mostly building planes with the foam. I was also concerned about moisture but from my wet sanding experience I can say that I have observed no adverse effects.
    The cuts need not be very smooth on the other hand it would have been good if I could have a rough shape carved out of eps foam. But I can sculpt by hand well so even if I only have an accurate cut I will be fine.
  1. Replies: 0
    Last Post: 04-02-2018, 02:48 PM
  2. Cutting wet or dry- Phase 2 for the Newb!
    By countryguy in forum Shopmaster/Shoptask
    Last Post: 12-17-2014, 08:31 PM
  3. Wet or dry? 4140A, having problems wet
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2012, 05:21 AM
  4. Prevent the z axis from cutting the table up
    By JimmyL in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-28-2009, 09:30 PM
  5. How to prevent cutting alumunium from clogging ?
    By Calico in forum MetalWork Discussion
    Last Post: 11-09-2006, 08:34 AM
