Hi all,
i am trying to figure out what is going on here.
Using Lasercut 5.3
What i am trying to do is the following, i want to engrave a few the same pieces and lay them next to each-other.
But first i have to make a layout so i know where to place the blocks i want to engrave.
I first save the image to DXF for example so i have layers that i can give a color and then set the laser power / speed / etc ( so the shape of the pieces of material that i like to engrave).
Then i want to engrave an image into the area i just made, use the logo and save it as png / jpg or whatever format lasercut can read.
Here is where the problem comes, if you watch the movie you can see what i mean, the image that i save for engraving is bigger then shape it is surrounded by, which i first wanted to use as a guide line.
I hope i explain it clearly enough
anybody knows what i am probably messing up here ?
