544,218 active members*
3,003 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > What are the essential tools to build an epoxy granite cnc
Results 1 to 6 of 6
    Sep 2016
    42
    I am considering building an epoxy granite cnc with a steel structure as buying one is beyond my budget. I need to factor the cost of tools that I would need to buy also. Appreciate if some one can point me to essential tools that I will require.
    Gold Member
    Apr 2004
    5338
    Re: What are the essential tools to build an epoxy granite cnc
    It would be helpful if you posted some pictures of what you're trying to do, so people here could better advise you on how to do it. If you're proposing a welded steel understructure, you'd need welding and metal-cutting tools at a minimum. If you're making a mold out of wood, you'll need woodworking tools. If you need to drill holes in your epoxy-granite casting to mount components, that will require special tooling as well. You'll also need some measuring tools to tell you how you're doing.
    Andrew Werby
    Website
    Mar 2017
    823
    The great thing about epoxy granite is that you don't need many special tools.
    For casting the epoxy granite machine base you'll need something to make a mold out of and mold release to start with.
    You can use a simple mdf mold if you apply the mold release properly. I used Meguiars Mirror Glaze mold release wax plus purple PVA mold release.
    If you're going to build something that's worth using then you'll probably want a shop crane too. Epoxy granite is incredibly heavy. I had to buy a 2 ton shop crane from Harbor Freight just to lift my epoxy granite gantry onto the base.
    Once it gets above a certain size, forget moving it by hand, even if you have help. Even a relatively modest EG benchtop mill can end up close to 1000lb.
    Casting the epoxy granite around a steel skeleton is a good idea. Epoxy granite does not hold screw threads well and you don't want to crack it.
    Based on my experience, I'd also suggest buying a bunch of steel or aluminum tubes for wherever you plan to attach other components with screws. Cast the tubes into the machine base. You don't want to be drilling through epoxy granite after it has cured.
    It cost me at least one cobalt drill bit for every hole I had to make through my EG gantry. Never again...
    Aside from this, most of the rest of the components are the same as what you'd need for any other cnc machine.
    I.e. You'll need an actuator for each axis and a spindle etc, plus a good way to mount them to the epoxy granite.
    I installed aluminum tooling plates (using long bolts going all the way through the EG gantry) over each mounting surface. These are already flat enough so no extra milling was required. You'll need something like this as you shouldn't attach rails or actuators directly to the EG.
    Jul 2018
    2949
    Hi Suspension - The thought that making a machine will cost less then buying a machine needs to be considered carefully. Have you priced second hand machines that do what you want? A refurbished machine is often the least cost option. You may have to wait to find the machine but once you have it the rest is straight forward. Making any CNC machine to a required tolerance can be difficult. There are several machines in the forum that needed much more work to get it to spec then the builder expected... What size machine are you looking at? and what accuracy are you aiming at? Peter
    Mar 2017
    823
    Quote Originally Posted by peteeng View Post
    I spent a long time agonizing over that myself before going ahead with my build.
    Thanks to all the failed small businesses ebay is full of low cost used VMCs and old Bridgeport style mills etc.
    Some of them are comparably priced to parts for a decent diy build. If any of the available used machines met my needs I probably would have gone that way.
    The problem I found was that there are very few (if any) cnc machines in that high quality benchtop / low cost, decent work envelope hobby category (new or used).
    Most off the shelf low cost cnc machines are overpriced aluminum t-slot kits or flimsy mini-mill conversions with tiny work areas.
    Most of the used VMCs weigh 5 tons+ and would require complete retro-fitting.
    I think Tormach tried to fill that niche of decent (ish) quality, small footprint / low cost VMC but they've become way too expensive (new or used) to be in the hobby space or be competitive with a diy build.
    While It's unrealistic to think a first diy build could match up to $100k+ industrial VMC precision, I think that building a Tormach quality epoxy granite machine is a reasonable goal. And you could do it on a typical $3000 hobby build budget with smart shopping.
    Ebay is also full of used high quality / low cost components from all the VMC part-outs. You can furnish a diy epoxy granite machine base with some very nice used cast iron milling tables, Cat40 spindles, tool changers, precision linear actuators, servo motors etc.
    Still... It's a long learning curve. If I didn't enjoy a diy build project I probably would have given up half way.
    Jul 2018
    2949
    Hi Suspension - To lower cost with no impact on performance consider UHPC or CSA concrete. Half the cost of epoxy granite (by volume) and potentially easier to achieve a good modulus. Can point you at a USA available one if you want to consider this. Peter
  1. Motor selection for an epoxy granite build
    By electrotwelve in forum General CNC Machine Related Electronics
    Last Post: 10-24-2019, 06:44 PM
  2. CNC lathe build, steel frame, HIWIN rails and epoxy granite headstock
    By Roadsidejobshop in forum Vertical Mill, Lathe Project Log
    Last Post: 01-12-2017, 04:02 AM
  3. Epoxy-Granite CNC Lathe Design (and Build)
    By romihs in forum Vertical Mill, Lathe Project Log
    Last Post: 02-16-2016, 06:07 PM
  4. 4Th axis add on build using epoxy granite and R8 spindle
    By Sil_x in forum Open Source CNC Machine Designs
    Last Post: 10-01-2011, 06:36 PM
  5. Essential and Desired Tools for JGRO Build?
    By forgetcolor in forum JGRO Router Table Design
    Last Post: 08-10-2007, 07:28 AM
