584,863 active members*
5,105 visitors online*
Results 1 to 11 of 11
    Aug 2020
    95
    What does this button do?
    Attached is a photo with a few buttons circled. Does anybody know what they do?
    Aug 2020
    95
    Re: What does this button do?
    No takers on this one?
    Nov 2012
    1267
    The bottom button apparently cuts the operator's finger off.
    Dec 2003
    24216
    I think MFI is the MDI manual data input. (Manual File Input)?
    The OT is overtravel overide, to allow move off of OT switch..?
    The I/O is could be display ladder.
    Just a guess.
    Al.
    Albert E.
    Dec 2003
    1206
    Is it really wise to be using the machine without knowing a bit more about it? It could get expensive and/or painful if you press the wrong button.How about telling us what make of machine and what controller?
    Dec 2003
    24216
    Seems I was close on MFI, Machine File Input via RS232 etc.
    Al.
    Albert E.
    Aug 2009
    1567
    ...USB drive... Machine From Input ?
    Aug 2020
    95
    Quote Originally Posted by routalot View Post
    Well, that is why I am asking what the buttons do! They dont appear to be related to the safe operation of the machine but still nice to know.
    The controller is a Mazak made controller found only on this exact Mazak Impulse 30 machine.
    Aug 2020
    95
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Interesting, I will have a look at the serial input when this button is pressed. Maybe it could be used for drip feeding or keyboard entry into the mdi? It has a whole screen for program reading and punching to tape.
    Aug 2020
    95
    So, i stumbled across this manual for my controller by accident today. So stoked!!! https://www.cnczone.com/forums/machi...t-imac-tp.html
    Anyways, it appears the functions of some of these buttons are (as correctly spotted by some people)
    - Over Travel Release
    - Auxiliary Key (MF1)
    - Still don't know what the other one does. Maybe related to tape or disk IO.
    Aug 2020
    95
    For future reference... I purchased a manual for the machine. Here is what the buttons do:
    - The key shared with F/E is screen on/off. Press it in combination with MF1 to turn the screen on and off. It will light up when the screen is off
    - MF1 is the 'auxiliary key'. It has multiple functions. Hold it down in combination with MST Lock, Machine Lock, Dry run menu items to activate them. Also used in combination with print button and screen on/off.
    - OT. Release. Hold this button down to release an over travel error. Seems this should only ever occur if you go too far in the wrong direction when homing the machine and hit the end of travel.
  1. Replies: 2
    Last Post: 10-18-2019, 12:12 PM
  2. Think I need a better placed RED Button
    By rdsi in forum Tormach PathPilot™
    Last Post: 02-05-2017, 08:29 PM
  3. v25: Hey...what's this button do?
    By moldmker in forum BobCad-Cam
    Last Post: 06-25-2012, 11:39 PM
  4. Set jog to 10% with button/key
    By EL34 in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-06-2012, 09:13 PM
  5. Need button
    By ozzie34231 in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2009, 03:35 PM
