550,246 active members*
3,227 visitors online*
    What is best cnc machine for noob.
    Hello what is the best cnc machine that can cut aluminum? That is affordable. Thanks. : )
    Nov 2013
    1540
    Re: What is best cnc machine for noob.
    the biggest hurdle to making a machine to do aluminum is rigidity.
    If you require rigidity R to do wood and plastics, then you'll need 5R to do aluminum, and 20R or more for steel.
    Most of the cheap Chinese CNC router tables are OK for wood and plastics but are not rigid enough to do a convincing job on aluminum.
    Probably the best value for money machine that's rigid enough are the like of a RF45 drill mill. They can be converted to CNC if you wish.
    Craig
    Jan 2018
    1097
    Manual Mill conversion is about it.
    PM25 size Mill as a minimum.
    RF45 size as suggested ideally for most versatility.
    DO NOT touch the sieg x2 size stuff.
  1. Noob looking to get into CNC with a 6040/6090 machine
    By cncnoob2019 in forum Chinese Machines
    Last Post: 08-29-2019, 12:51 PM
  2. CNC NOOB builds a modified Grunblau machine
    By braef in forum DIY CNC Router Table Machines
    Last Post: 02-14-2017, 11:24 PM
  3. noob making my first cnc machine
    By mrn in forum Uncategorised WoodWorking Machines
    Last Post: 10-17-2012, 10:05 PM
  4. Looking to build a CNC machine - im a noob
    By charlieiscool12 in forum DIY CNC Router Table Machines
    Last Post: 05-29-2010, 03:24 AM
  5. CNC noob needs a machine
    By bootdc in forum CNC Wood Router Project Log
    Last Post: 05-18-2005, 11:35 PM
