548,477 active members*
2,955 visitors online*
IndustryArena Forum > MetalWorking > General MetalWork Discussion > What steel would you machine these from?
Results 1 to 9 of 9
    Apr 2011
    79
    Hi
    First I'm a newbie so I've tagged this post as such.
    I bought my first CNC lathe and mill. They came from surplus and are missing a few parts. I'd like to make them. Note, this is a long term plan. I don't plan to make them as my first project(s) as I need to begin much simpler but I am curious as to the general practicality of the task.
    - The first is a tooling plate. It attaches to a rotary changer. Mine came missing the plate. I bought an entire new changer with plate but I'd like to make a replacement plate.
    - The second is a tool holder for a mill pneumatic automatic tool changer. The holder is no longer in production. I was able to find one. I realize it's probably easier to adapt a different holder still in production such as a Tormach but I'd like to try making replacements.
    My questions:
    - What material would you make these from? Some kind of tooling steel? Or is that unnecessary for work holding? Can anyone recommend a good resource that discusses the basics of material selection for particular tasks? Obviously it's a wide ranging topic that could rapidly get complex for very specific tasks.
    - For the blackening I assume they dipped them and then did a thin cut to selectively remove?
    Dec 2013
    5176
    Re: What steel would you machine these from?
    For the tooling plate I would make that from 4140 or 4340, or at least one of the 4xxx series of steel. Good strength and reasonably easy to machine. Can be heat treated if desired.
    For the tool holder, I would use 4150, or maybe a heavy truck axle or hydraulic cylinder rod if you can find one at a scrap yard. Since you are local, Clackamas Steel has a bunch of hydraulic cylinder rods on the shelf at reasonable prices, to the left of the drive through. But before I went through the work of building one from scratch, I would see if it's possible to modify an existing holder.
    In this case, the blackening is most likely an artifact from the heat treatment, prior to finish grinding. There are several methods of blackening steel if you want to do that, I personally use gun bluing for my projects.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2005
    13132
    Quote Originally Posted by crazybrit View Post
    Hi
    My questions:
    What are the Machines that you can't get tool holders for, some photo's of the machines would be good.
    Mactec54
    Apr 2011
    79
    Light Machines Prolight. I can use other brands (like Tormach) if I make new dogs for the changer (I said in the initial post that I knew this). My question was about making my own. Everyone has a differing ideas on how to spend their time, value of their time ;-)
    Quote Originally Posted by Jim Dawson View Post
    Since you are local, Clackamas Steel .
    i refuse to go there. They suck. If you read their reviews I am far from alone in this opinion.
    Jan 2005
    13132
    Yes by all means make your own parts / Tooling, I do it all the time, material can almost be anything, depending on how long you want it to last, From 1214 free machining mild steel to prehard P20 which machines ok, and is already heat treated makes good tooling with no other treatment needed.
    Mactec54
    Apr 2011
    79
    Are there any good resources that discuss different types of steel and methods of heat treating that are suitable for the hobbyist?
    Jan 2005
    13132
    That is why I said P20 would be a good choice as heat treatment is not needed.
    01 is another steel used for lots of parts, and is easy to heat treat, with a torch for heating it up then quench in oil, ( Canola oil works very well ) then temper in you toaster oven
    If you want to learn about heat treatment and different steels, eBay has this that may help, eBay # 162544948596
    Some heat treating you would have done by company that specializes in Heat Treater
    Mactec54
    Apr 2011
    79
    Answering my own question.
    Heat Treatment, Selection, and Application of Tool Steels 2E 2nd Edition (2009)
    by William E. Bryson
    In addition to lots of info about heat-treatment, chapter 20 is dedicated to tool steel selection
    "What you’re about to read in this chapter is a method of selecting
    tool steels with today’s most popular grades in mind. However, there are
    also some steels discussed here that have lost much of their popularity
    in the past few years and are becoming more and more difficult to buy
    in the marketplace"
    While I'm sure lots of old info on that eBay DVD still applies, I was hoping for something more recent and this seems to fit the bill.
    Jan 2005
    13132
    in the marketplace"
    Yes there are many books just like this, even an App for your phone, :banana: Heat treating practices have not changed no matter how old the information is, Tool Steels are just the same and the process for Heat Treating them, is much older than you are, so any information on Heat Treatment would be valid information
    The parts you show in your post are not made from Tool Steel, and would never be made with Tool Steel, they are made from high carbon steel, En32 or EN36 or similar brand name Steel, they are just case hardened parts, so knowing about how to Heat Treat Tool Steel, won't do you much good. you need to know about Case Hardening and Core Refinement, and then be able to Grind the parts after Heat Treating
    Mactec54
  1. Replies: 1
    Last Post: 03-01-2021, 12:19 AM
  2. open source machine to machine a flat surface on a steel tube or an applied strip on
    By JohnMcNamara in forum DIY CNC Router Table Machines
    Last Post: 02-19-2021, 12:22 PM
  3. Replies: 4
    Last Post: 07-05-2017, 06:05 AM
  4. Steel machine parts
    By paulcad in forum USA RFQ's
    Last Post: 03-04-2016, 02:59 AM
  5. new machine, aluminum or steel ?
    By max_imum2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2006, 02:29 PM
