559,953 active members*
2,556 visitors online*
IndustryArena Forum > MetalWorking > General MetalWork Discussion > What tool to cut copper sheet?
Results 1 to 4 of 4
    Aug 2022
    19
    Advise me on the best way to cut copper. Can it be done on a CNC laser machine?
    Aug 2022
    19
    Re: What tool to cut copper sheet?
    Of course, a lot depends on the thickness of the copper sheet...
    Aug 2022
    19
    Yes, it's depends on the thickness of the copper sheet. But as a rule, sheet copper is cut with conventional guillotines (guillotine shears). Not a bad value for money. Less technologically advanced than laser cutting, but also a good option.
    BETTER! On a metal laser cutting machine. Expensive, but a professional method. The advantage is that there is fiber protection from being shot off. True, you can't cut thick sheets, up to about 4 mm you can.
    Lets make amazing products with cnc wood router
