531,641 active members*
3,626 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > What would cause inconsistent "lines" like this?
Results 1 to 8 of 8
    Nov 2019
    22
    I am confused as to why I am getting inconsistent lines when surfacing my spoil board with a 2" cutter (1" step over) after tramming to .004" difference over 6" inches. The existence of the lines is not so much the greatest concern (should it be at .004"?), but the inconsistency of the lines is what I do not understand. Why would I get lines is some areas but not consistently across the spoil board?
    I trammed my Joe's Hybrid CNC using a tramming squaring from SST with two dial indicators. With the gantry near centered on the x and y axis, the front to back measurement is about .004" different and the left-to-right is about .0005" different. Both of those measurements are across 6" from dial indicator to dial indicator. The dial indicators are measuring against a 1/4"x20"x20" piece of glass that has been made parallel to the x and y axis prior to the measurements/adjustments above. Example: https://cdn.thingiverse.com/assets/8...132807_200.jpg (not my image, but that is the technique I used)
    Gold Member
    Apr 2004
    5164
    Re: What would cause inconsistent "lines" like this?
    Is this the first series of surfacing cuts or the second? If it's the initial surfacing pass, the unevenness is probably happening because your bed wasn't flat.
    Andrew Werby
    Website
    Nov 2019
    22
    2 full passes using the same pattern (front to back). Taking 1/32" off the first pass. And not changing the Z depth for the second pass (aka it stayed at z-0.0032 without re-zeroing Z).
    Dec 2003
    751
    What happens if you do the skimming cut across the spoilboard?The only time i have found this kind of issue was with a badly built machine that had some flex in the rails and it dug in a touch going one way and lifted a bit going the other way.Changing direction may just help with this operation,but could in itself,be highlighting a flaw that needs further investigation.
    Aug 2009
    758
    ...non precision machine...well oiled . sunburned wood chucker...ing chucking saw dust anymore questions?
    Mar 2003
    35168
    Does the machine use V rollers on angle iron? If it is, it could be variation in the angle iron.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2019
    22
    It does use V rollers on angle iron. I did a feel test of the top angle iron and was not able to make a connection between unevenness of the angle iron with marks on the spoil board.That said, yes this was my #2 suspect.
    Do folks have a process for addressing variations in angle iron/v-bearing setups? Other than replacing them with linear bearings. :-) (want to, but cannot justify the effort or financial expense yet)
    I did recheck the tramming after the surfacing passes to confirm the Z axis had not lost its true (it did not).
    Mar 2003
    35168
    Replace the angle with the proper guide rails for the V rollers.
    https://www.pbclinear.com/Products/C...-Bearing-Wheel
    Gerry
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Contour tab "witness lines" ?
    By Kosh in forum CNC Router Parts
    Last Post: 12-24-2017, 07:30 AM
  3. problem "lag" on k40 speed slows down on some lines engraving halftones image
    By hargossath in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 05-22-2016, 07:20 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 05-06-2013, 09:59 AM
  5. Teach me how to "Group" entities and lines
    By fretsman in forum Autodesk
    Last Post: 12-31-2007, 10:18 PM
