Just cant get the material to pull down tight. Not sure what to do, allready on second sheet of ABS and no real improvment.
I think I have plenty of heat, watch the temp with infrared thermal thermometer, to adout 350 degrees ferinhieght.
I just finished building a 24'' x 42'' machine. playing on 1/8 ABS the specs of the machine are:
11pcs straight tube elements 600 watts set in 5 zones
holes in base plate 1/4 and 3'' grid also v groved grid lines
1'' x 24 x 42 vacuum chamber
second platten brought up level to material ( with grid & 1/4 holes )
1500 watt 240 vacuum , and 12 gal 5.5 Shop vac,
Neopreem gaskets under material frame and in it.
I also tried a vacuum pump and tank system and results where worse.
