601,652 active members*
2,497 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Where can I buy an upgraded laser module for my BangGood 650 x 500
Results 1 to 6 of 6
    Nov 2019
    3
    I have a BangGood 650 x 500 laser engraving machine that is home built. I am satisfied with it and have used it for some years successfully. I would like to build a model ship and cut the pieces from 5mm laser plywood. Can anyone tell me if I can replace the 2.5w blue laser module with a module that will cut through 5mm plywood. It will need to be something simple like a straight, old module off and the new module screwed on.
    Anyone help please ??
    doncraig
    Nov 2019
    3
    Re: Where can I buy an upgraded laser module for my BangGood 650 x 500
    I don't see any relevant answers in the similar threads that suit my problem. Is there any more places to look for a new laser module that will fit
    Quote Originally Posted by doncraig View Post
    doncraig
    Maybe you can try NEJE A40640 or A40650 (10W optical)
    or Atomstack M50 / S10 Pro Modules
    Nov 2019
    3
    Thanks very much for your help cncmakers001 it is much appreciated.
    I will look up the relevant sites
    doncraig
    Nov 2019
    3
    Thanks again cncmakers001. I have had a look at your suggestions and the results are upsetting. The manufacturers are more interested in pushing a new machine rather than giving help on replacing a module. One suggested a new machine priced at over £3000 GBP ??
    I will be looking at possibly a Ortur machine if I can get it cheaply enough.
    doncraig
    Nov 2019
    3
    Thanks for all your help especially cncmakers001. I have ordered a new Atomstack Laser Engraver, A5 M50 Pro 40W Laser Engraving Cutting machine, 410 x 400 cutting area that will cut 5mm thick plywood that I want to build my model wooden boats. No doubt I will be on their forums with a load of problems to get me started. Thanks again
    doncraig
  1. Replies: 1
    Last Post: 01-04-2021, 01:53 AM
  2. WTB: Roland ZAT-650 ATC control module (for MDX-650A)
    By trevorstach in forum Benchtop Machines
    Last Post: 11-09-2018, 08:12 AM
  3. Looking at Banggood Desktop laser engraver. Need opinions
    By gregrlevy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-15-2018, 05:10 AM
  4. Banggood 7w Laser Mounted to CNC Machine
    By denmark219 in forum Laser Hardware
    Last Post: 06-27-2017, 01:24 PM
  5. I am looking to buy roland mdx 540/650
    By stafoil94 in forum Want To Buy...Need help!
    Last Post: 02-01-2017, 07:45 PM
