Which brand of fiber laser cutting machine is easy to use? In fact, the choice of fiber laser cutting machine which brand is not the most important, the most important thing is to look at the company's own needs, choose the right enterprise fiber laser cutting machine. Zhengzhou Baiwei CNC Machinery Shares Co., Ltd. is your best choice.
Hydraulic Guillotine Shearing Machine
Buy fiber laser cutting machine to see what industry it is, different fiber laser cutting machine manufacturers focus is not the same, some manufacturers focus on small fiber laser cutting machine, high-power products are few. And Hongshan laser products Mainly focus on small and medium-sized fiber laser cutting machine, the power of the machine is more than 500w-2000w. The following points can be referred to when purchasing fiber laser cutting machine:
First, the choice of models
CNC Hydraulic Guillotine Shearing Machine
To purchase a fiber laser cutting machine, it is necessary to determine the type of equipment to be purchased, depending on the material and thickness of the processed product, and the quality and cutting speed of the cutting product. This is a plate-specific machine, tube-specific machine, or tube-sheet machine.
Second, configuration selection
According to the material and processing requirements of the processed product, especially the processing thickness and piercing ability, the configuration of the laser cutting machine is selected, such as the power of the device.
Hydraulic Plate Sheet Bending Machine
Third, examine the stability of the machine
The CNC system is the most important part of a laser cutting machine. It determines the value of the equipment and is one of the key factors in selecting the machine. The hardware of the CNC system determines the stability of the system, and the control software determines the cutting quality of the fiber laser cutting machine. And efficiency.
CNC Press Brake
Fourth, airport quality and accuracy
After determining the model and configuration, the quality and precision of the fiber laser cutting machine can be observed. The airport structure of the fiber laser cutting machine, the quality of the gears, the machine installation grounding, and the accuracy verification of the fiber laser cutting machine are all related to each other. The factors of the cutting quality of fiber laser cutting machine.
Fifth, observe the cutting quality and efficiency of equipment
The cutting quality and speed can be directly seen, and it is also of decisive significance to the user's final use. It is to evaluate the overall performance of a fiber laser cutting machine. This user can directly go to the factory to conduct a field inspection and can request the factory. Processing some samples to observe the cutting quality and speed.
