525,379 active members*
2,681 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Why are cheap routers all aluminium construction ?
Results 1 to 4 of 4
    May 2005
    1563
    Looking at the Chinese 30xx and 60xx and various low cost offerings from other parts of the world aluminium is everywhere. I understand the convenience aspect of extrusions but even the parts that are made from plate and bar are aluminium. For a manufacturer working with steel shouldn't be a big obstacle and (at least where I live) it's much less expensive. If bolting steel to aluminium were a problem my car would have fallen apart years ago. One thought is aluminium is simply looks better raw.
    Anyone who says "It only goes together one way" has no imagination.
    Neuer Benutzer
    Jan 2013
    588
    Re: Why are cheap routers all aluminium construction ?
    The answer is in bold.
    Jul 2018
    1574
    Hi CS - One component of the total cost is finishing and paint is actually quite expensive, especially with many small parts. They have to be racked painted unracked etc. So aluminium does not need any of this. It's actually cheaper for me to have laser cut stainless steel parts then to have mild steel parts cut and painted. Plus the construction type extrusions suit the kit market, no holes need just cut to length and use the slots. Cheers Peter
    Mar 2003
    35012
    Extrusions make assembly faster, and the lighter weight probably saves on shipping costs.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Cheap/free Aluminium Eggcrate in Australia
    By Things in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 03-21-2013, 11:17 AM
  2. Hitachi Routers available cheap, 1 year warranty $80!
    By jonathanm in forum DIY CNC Router Table Machines
    Last Post: 08-26-2011, 10:07 AM
  3. Aluminium Profieles Where to Buy them Cheap?
    By andycorleone in forum DIY CNC Router Table Machines
    Last Post: 05-03-2011, 03:17 AM
  4. who sells cheap cnc routers?
    By FireFghtr in forum DIY CNC Router Table Machines
    Last Post: 11-24-2005, 11:27 PM
