529,699 active members*
2,502 visitors online*
Results 1 to 1 of 1
    Cool Why Choose EETO Laser Cutting System?
    Application
    Material: carbon steel, stainless steel, aluminum, brass, gold, silver, galvanized sheet., etc.
    Industry: sheet metal fabrication, electrical cabinet, medical, advertisement, automotive, building., etc.
    EETO Laser High Power Fiber Laser Cutting Machine FLX GII, a new-generation industrial-class design, which can adopt high precision transmission components and parts with closed-loop EtherCAT control system ensuring fast and precise cutting.
    In addition, our PRECITEC auto-focus laser-cut manageS to reduce the piercing time of thick metal cutting. The advanced elevation type exchange pallet makes it easy to improve working efficiency(fastest 16s), stability and maintenance.
    Beckhoff closed-loop etherCAT control system ensuring ultra- fast and precise cutting.
    Adopted high precision transmission components and parts, such as reducer (Alpha), gear and pinion.
    Complete processing procedures ensuring body long term stability and high positioning accuracy (≤±0.02mm).
    Max acceleration 1.5G eg. 1mm stainless steel cutting speed 80m/min.
    Cutting head built-in zoom module, realize the function of collimating module, get 1.2-2.0 times spot diameter, and the focus position is automatically compensated.
    Partition ventilation system to improve around 70%-80% fume-extracting effectiveness VS other traditional designs.
