547,048 active members*
2,350 visitors online*
    May 2008
    43
    Why did this defect on occur ?
    I'm relatively new to 3D printing. Done quite a bit over the past month or so but am still learning setting etc.
    The item in the attached photo was printed on my FlashForge Adventurer 3 printer.
    95°C bed temperature
    135°C nozzle
    ABS
    .4mm first layer
    No raft
    As you can see in the photo the bottom layer(s) moved during the 2.5 hour build. I think it was probably caused by my increase of the first layer from .28mm to .4mm but would like to hear what others think. Bed too hot perhaps for such a long construction time?
    Thanks,
    BH
    Oct 2021
    Re: Why did this defect on occur ?
    Often, a print's https://bestsublimationsprinter.com/...for-beginners/ initial base layer is programmed with extrusion rates greater than 100% in an effort to ensure the part adheres to the bed. The result is an initial base layer that's wider than designed.
  1. Is there anyway to control where plunges occur?
    By John Coloccia in forum MadCAM
    Last Post: 02-24-2014, 04:39 PM
  2. Replies: 0
    Last Post: 06-08-2012, 07:28 AM
  3. keyboard defect
    By legusto in forum HEIDENHAIN -> GENERIC
    Last Post: 02-23-2012, 07:56 AM
  4. what faults generally occur in a servo motor & its driver ?
    By danishdeshmuk in forum CNC Teknix Servo Control Products
    Last Post: 11-23-2011, 08:38 PM
