As you know, The ink jet printers must operate normally and are well maintained, and must use the inks specified by the manufacturers. Many people cannot accept such "hegemonic" consumption at the beginning. Because the price of consumables is very high which provided by some printer manufacturers. They think there is a cheaper ink can be replaced on the market. In their mind, the ink is a dark liquid,just can be print on material i s ok. More, there are some misleading statements about the ink on the Internet, so some customers prefer to choose cheap inkjet printer ink to reduce production costs.In this regard, Perfect Laser reminded all of inkjet printer customers once again, catch not at shadow and lose the substance, just to pursuit the short-term benefits. the factory remind customers to buy the specified ink is justified.
Of course, if you just use a brush to write, then any price of ink is OK, The supplier will not say that you must use our ink, or the brush will be broken.Here, I want to say is that the general pigment-type inkjet printer ink is actually not a simple liquid, but the granular powder is fused in the liquid, the inkjet printer as a precision instrument, the use of the printer The size of the particles contained in the ink is very important, especially the nozzle part. Inkjet printer inks are generally quick-drying, and inferior inks contain large particles. Even dye-based black inks have very strict and complex distribution ratios. Therefore, mismatched inks can easily cause nozzle clogging,damage to the filter,and causing the ink system to crash.As we all know, the core part of the printer is the circuit system and the ink system. Once the ink system crashes, it is not so simple after-sales maintenance.
Furthermore, even the solvents and inks provided by the printer manufacturers will have different models. Manufacturers will generally choose the most suitable printer ink type according to customer needs when formulating the labeling solution, because different types of inks and additives must not be mixed, otherwise it will cause chemical reactions, causing various problems in the machine, and the ink system also may crash because of this.
As for the printer ink provided by the manufacturer is expensive, then I can only say a penny a point, after all, some manufacturers provide the ink is imported, the quality of the ink is much higher than some domestic, and thus the production cost is not low, plus the costs incurred by transportation and customs, such prices have been formed in the domestic market. For example, the inks provided by the Lottronic company Rottweil are imported from Germany, and the quality is guaranteed. Therefore, the price will be a little higher than domestic ink, but it is definitely within the range that customers can accept.
Therefore, in the procurement process, customers not only need to select the right inkjet printer, but also choose the correct inkjet printer ink. In fact, in the long run, the use of good ink, so that the normal operation of the printer itself and maintenance is guaranteed, which is more cost-effective than using inferior ink to reduce production costs. I believe wise customers should know what to do.
