585,727 active members*
3,815 visitors online*
Thread: Will it Fit
Results 1 to 9 of 9
    Feb 2019
    38
    Will it Fit
    Okay... I did it. I purchased a Hardinge Conquest T42 with live tools, C-Axis, big bore and Tailstock. I also got about 10 live tools as well as a bunch of static tool holders.
    I pick it up tomorrow and am wondering if it fit through my double doors, which are 72 with the doors removed.
    Some specs I read say the machine is 70" wide while others state 76" wide. Which is it? If it is indeed 76" wide, can I remove covers or some other things that would allow it to squeeze through the doors? I would love to hear your thoughts.
    Thanks,
    David
    Dec 2013
    5717
    Re: Will it Fit
    I just measured my Conquest 42, which is NOT a T-42. It's 80L x 55W x 68H. 10,200 LBS. Not sure if this helps.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    Re: Will it Fit
    Thanks Jim. At least it's in the right direction.
    Feb 2019
    38
    Re: Will it Fit
    It fit... one inch to spare.
    Dec 2013
    5717
    Re: Will it Fit
    Congratulations! :cheers:
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    Re: Will it Fit
    Here are some pix.
    Dec 2013
    5717
    Re: Will it Fit
    Looking good. You are going to love that machine, very repeatable. Mine holds +/- 0.0001 consistently, not bad for a 30 year old machine.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    Re: Will it Fit
    Quote Originally Posted by Jim Dawson View Post
    Thanks!!!! I'm having a hard time finding square tool holders for the turret. Any ideas on where to get this stuff or workarounds?
    Dec 2013
    5717
    Re: Will it Fit
    I took a look on EBay and didn't find anything. Pretty sure you can get them from Hardinge.....$$$ If you have the manuals for the machine the part numbers should be in there. You could also build some. The geometry is not complicated. 4150 or 4340 would make good tool holders. I can supply pictures and dimensions if you like. I don't know if my turret is the same as yours, but it might give you a starting point.
    Jim Dawson
    Sandy, Oregon, USA
