579,057 active members*
9,405 visitors online*
Results 1 to 14 of 14
    Apr 2008
    46
    WinXiso-Xilog
    Hi All,
    I I am trying to generate code for an SCM Routech with Aspire. I have a post processor and it generates the .pgm file I need. The issue is I don't have access to the CNC at the moment and I wan't to verify that the post is correct and I cannot read the code in the .pgm file as it is not a standard text file.
    Would anyone be able to convert the pgm file to a .xxl file for me using WinXiso? Or possibly share WinXiso with me? Then I can read the file and verify that the code matches the sample files that I have been given.
    Thanks in advance.
    Richard
    Mar 2003
    35538
    Re: WinXiso-Xilog
    Are you sure you have that correct?
    On our Morbidelli, the .pgm is a binary file. I wrote an Aspire post to create the .xxl file, and used WinXIso to create the .pgm file.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2008
    46
    Re: WinXiso-Xilog
    Yes.. My post generates a .pgm file l just can't read it at home. I know what the
    Xxl file should look like so I want to use winxiso to convert from .pgm to .xxl. Which it can do. Then l can verify the output of my post.
    Would you be able to convert a .pgm file for me?
    Regards
    Richard
    Mar 2003
    35538
    Re: WinXiso-Xilog
    .zip it and post it here and I'll see.
    Gerry
    Apr 2008
    46
    Re: WinXiso-Xilog
    Attachment 235630
    Here you go.
    If you can covert it to an .xxl that would be great.
    Also if you are able to share Winxiso that would be good.
    Richard
    Mar 2003
    35538
    Re: WinXiso-Xilog
    Either you're not doing it right, or your machine is different than ours.
    With our machine, .pgm files are binary. We output .xxl files from our CAM and convert to .pgm with WinXIso.
    As such, your file doesn't work, as WinXIso expects .pgm files to be binary.
    Renaming your file to .xxl, and running it through WinXIso results in a binary .pgm file, which I've attached.
    Attached Files Attached Files
    Gerry
    Apr 2008
    46
    Re: WinXiso-Xilog
    Thank you. I will look at the file you sent.
    So it sounds like my post processor is changing the extension to a .pgm but not converting it to binary.
    Thanks for your help.
    Sent from my HUAWEI U8681 using Tapatalk
    Apr 2008
    46
    Re: WinXiso-Xilog
    Is there anyway you could send me the winxiso .exe? This way I can debug this post before l get access to the controller.
    Thanks again
    Mar 2017
    Re: WinXiso-Xilog
    Hi All,
    First apologize for my bad english. I'm use to Morbidelli Author 430S and i have a *.pgm problem. How can i found a download link for Winxiso.
    Thanks.
    Aug 2016
    5
    Re: WinXiso-Xilog
    Please send me your e-mail so I can send you Winxiso.
    Regards.
    Feb 2019
    6
    Re: WinXiso-Xilog
    Hi there alias_s im also looking for WinXiso would you be able to help
    Re: WinXiso-Xilog
    Hola por casualidad tienen un postprocesador para un scmtech z25 estoy usando alphacam y no sé cómo convertir esos archivos .anc a pgm
    Jan 2016
    I need a program to convert outout file from Aspire to .PGM for Moorbidelli U26.
    Thank you
    Mar 2022
    Re: WinXiso-Xilog
    I looking for download link for Winxiso too.
    Oct 2022
    11
    Re: WinXiso-Xilog
    Quote Originally Posted by alias_s View Post
    Regards.
    my email is bnsnlai@hotmail.com
    Please and thank you also looking for Winxiso
    Mar 2022
    23
    Re: WinXiso-Xilog
    I assume that this is solved?
  1. Need help scm xilog
    By Markoav in forum Mentors & Apprentice Locator
    Last Post: 12-12-2015, 03:43 AM
  2. WinXiso-Xilog
    By junglist in forum Uncategorised WoodWorking Machines
    Last Post: 05-06-2014, 10:19 AM
  3. WinXiso-Xilog
    By junglist in forum BobCad Post Processors
    Last Post: 05-06-2014, 10:17 AM
  4. Morbidelli Author 503 - PGM files using WINXISO
    By simon_vr in forum Uncategorised CAM Discussion
    Last Post: 06-13-2013, 12:53 AM
  5. Xilog+ and W7
    By Malgiliath in forum Commercial CNC Wood Routers
    Last Post: 10-24-2010, 09:04 PM
