549,879 active members*
1,590 visitors online*
    Aug 2008
    335
    WIRE EDM PROBLEM
    Had a battery alarm replaced the batteries and alarm will not clear .It appers as the two wires on the bottom battery box have become cut ??? Machine was working the night before...Machine is a elox O wire edm with a OM Fanuc controller .It uses AC servo motors and drives . Can any one help .Need wire schmatic of lower battery box . Had a 336 346 alarm 0 voltage absolute pulse encoder alarm for u and v axis . I made the machine think its a two axis machine to run parts but need to fix this can anyone help ?
    Aug 2008
    335
    Re: WIRE EDM PROBLEM
    Problem solved .
  1. Replies: 4
    Last Post: 01-14-2022, 12:48 AM
  2. Problem with Brother Wire EDM
    By JINX222 in forum General Waterjet
    Last Post: 01-17-2020, 09:12 PM
  3. Sodick Wire EDM problem ??
    By Stiga in forum General EDM Discussion
    Last Post: 05-10-2015, 09:47 PM
  4. Chinese wire EDM problem
    By gombault in forum General EDM Discussion
    Last Post: 03-23-2010, 06:31 AM
  5. Wire EDM Problem's
    By weirdharold in forum UG NX
    Last Post: 11-18-2009, 08:51 AM
