544,220 active members*
2,986 visitors online*
    Feb 2015
    5
    wiring my new laser
    Hi all, I have been trying this puzzle now for days. Any help would be great. I tried de pinning the white wire going from the laser to the power board and hooking it to the pwm pin on the control board. I dont know what to do and I dont want to mess anything up. The first pic is the power board. The second pic is the control board, the laser connector is the upper right to the right of the switch. the third pic is the laser. Right now there is a wire from the laser to the power board and a blue wire with a connector. If the power block is plugged in the laser is on unless you press the little button on the board.
ID:	463917Click image for larger version.
ID:	463919Click image for larger version.
    Feb 2015
    5
    Re: wiring my new laser
    I have also tryed putting the white and black wire from the laser to the control board and just the red wire to the power supply board. the red light on the power board is on but i still get no response from the laser.
