532,047 active members*
3,478 visitors online*
    WoodWop 7 variable error
    Could someone give some advice on how to solve the variable error? I know it is something simple, but I really have no idea how to return it, the operator put the amount and then put the letter "i" to multiply it and convert it to inches, but It no longer does it and the old files of woodwop 7 stopped showing correctly, so I think that after changing the configuration, do you know how to reset the configurations or take steps back?Here I leave the sample images, if you respond, in advance thank you,
    Nov 2017
    11
    Re: WoodWop 7 variable error
    I d'ont really understand what is your problem... Your dxf conversion seems failing, i think, did you put your workpiece on the correct named layer "S_18" or "ProcPart_18" where 18mm is the thickness of the piece? Are you sure your piece definition variable and woodwop variable are matching? Send a .mpr, i can take a look.
  1. ERROR User variable not declared MOVE_NEEDED
    By Wurzell in forum Alphacam
    Last Post: 11-02-2020, 10:56 PM
  2. Replies: 1
    Last Post: 12-16-2015, 11:39 PM
  3. Error during readout of a system variable
    By Michi1965 in forum SIEMENS > Sinumerik 802D/840D/810D/828D
    Last Post: 09-08-2009, 10:19 PM
  4. Error when trying to set variable
    By tonper in forum G-Code Programing
    Last Post: 03-17-2009, 02:12 PM
  5. variable subscript out of range error
    By hideaway in forum G-Code Programing
    Last Post: 03-15-2008, 06:57 PM
