585,991 active members*
4,725 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > WORM SHAFT MACHINING ON LATHE
    Nov 2020
    3
    Post WORM SHAFT MACHINING ON LATHE
    Hi
    Can sameone help me with worm shaft machining on lathe HAAS ST 25,if is posible.
    Picture in description
    Dec 2013
    5717
    Re: WORM SHAFT MACHINING ON LATHE
    Anything is possible if you are clever enough, it is only a matter of tooling and the G code. We need a lot more information to be able to help.
    Jim Dawson
    Sandy, Oregon, USA
