527,864 active members*
2,311 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > writing tool offsets from within program
Results 1 to 10 of 10
    Aug 2010
    167
    id like to be able to write to my tool offset page from within a program, is this possible?
    i know this vvv works for writing to the work co-ords, but what about the tool offset page?
    VZOFX[11]=XX.XXX
    VZOFY[11]=YY.YYY
    VZOFZ[11]=ZZ.ZZZ
    VZOFA[11]=AA.AAA
    OSP200M controller
    Feb 2011
    305
    Re: writing tool offsets from within program
    These are read/write variables
    VTOFH=z.zzzz is for tool height
    VTOFD=d.dddd is for tool dia./ radius
    Jun 2015
    3195
    hy, those shared by rcs are ok; check also these examples :
    ... vtofd [ 01 ] = 20 ( rad declaration for register 1 )
    ... vtofh [ 10 ] = 123 ( height declaration for register 10 )
    ... vacod, active wcs ( example : back-up of active wcs : vzof*[vacod+20]=vzof*[vacod] )
    ... reading active :
    ...... rad : vc* = vtofd [ vtlcn ]
    ...... height vc* = :
    ......... vtofh [ vtlcn ]
    ......... abs [ vwkaz - vwkbz ]
    ......... vtoht [ vtlcn , vhcod ]
    ... targeting 10mm away from maximum z, regardless of wcs : vpplz - vwkaz + vwkbz - 10 ( is ok for defining clearance positions, that are absolute, not relative to wcs; similar to home positions .... more precise, home positions are relative to a virtual wcs that has vzof*=0, but can not be activated by using G15 )
    so yes, it can be done, and may seem nice when you see that it works
    but is it worthy to skip tool setting, by using g-code for auto-initialization ? if you wish to describe what you wish to do, i may help you to speed it up; for example, considering that you have all offsets value inside a file ( sent to the machine through network ) , simply use a gui ( from machine screen ) to declare atc pots inside which you installed your new tools, and create a program to auto-initialie offset only for those; keystrokes example : open, 4 5 12 52, create, program-select, cycle-start; such a method can be used to corelate tool-presseting equipment with machine, even for equipment that is not calibrated for a machine ... there may be room for improvement, depending what are you after / kindly
    Aug 2010
    167
    i was mostly looking for a simple way for my operators to run some roughing passes, followed by a finishing pass on some simple parts.
    Was looking for an easy way for them to program something like this at the controller rather than using our CAM systems.
    this along with a nice, clean and simple sub routine call for the part profile will be just what i wanted. simple, clean, easy to read.
    Jun 2015
    3195
    what about i-map ?
    Aug 2010
    167
    Quote Originally Posted by deadlykitten View Post
    what about i-map ?
    we hate it, seems like more work to get it to do what we want than its worth.
    Jun 2015
    3195
    yes, this is true all conversationals are a wonder at 1st glance, but after a while, when one gets used with them, may desire for more
    i have created a few codes, in order to speed up programing, being able to behave simple, or more complex
    i believe that you had been thinking about a simpler way
    is possible to reduce programing time for simple operations, using a pc conected to machines, or on-machine installed applications, or excel macros / kindly
    Aug 2010
    167
    im not new to coding, but am new to this type of coding and its capabilities. is there a list somewhere of these types of functions?
    VTOFH
    VTOFD
    VZOFX
    ECT
    ECT
    ECT...
    i would like to do my own research and play with them, to gain a better understanding of how they work
    Aug 2010
    167
    nevermind, found them :withstupi
    Feb 2011
    305
    I get the system variables from the back pages of a OKUMA osp200m instruction manual
  1. Writing tool and work offsets to a program??
    By GeorgeDV5100 in forum Polls
    Last Post: 06-18-2013, 04:32 PM
  2. Writing of macro program
    By Freiburgerr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-03-2010, 08:34 AM
  3. G Code Program writing
    By Tool Guy 1234 in forum G-Code Programing
    Last Post: 04-24-2010, 12:33 AM
  4. Replies: 1
    Last Post: 07-13-2008, 05:06 AM
  5. Set Tool Offsets in NC Program??
    By alfalfa in forum CamSoft Products
    Last Post: 10-06-2005, 05:47 PM
