594,914 active members*
4,507 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > WS55-180 is blinking red in groups of 7
Results 1 to 4 of 4
    Sep 2017
    9
    I have just tried to test my diy CNC engraver. No luck.
    Its WS55-180 has a steady green LED and a red LED blinking in what appears to be groups of 7.
    Supply voltage is 48.1v, and motor coils are all 4 ohms.
    The gap after the 7th blink appears to be a bit longer, but could be my imagination.
    Does a list of error codes exist, and if so, where?
    May 2016
    Angry Re: WS55-180 is blinking red in groups of 7
    Hai I starting with a WS55-180 driver and a adjustable power supply. In most cases the driver is flasing the red light. Sometimes the spidel is starting. But
    when I stop the motor using the pot meter the motor is not starting again. When I switch off the power and wait 1/2 hour it is some times working again.
    I have checked the wiring and the voltage level but all is ok.
    When I stop the spindel using the pot the red let is starting blinking and when I try to restart the spindel it is not working
    It seems that the driver is not starting and the red les is blinking continuously
    Nov 2024
    Hello, is there any solution for this problem?
    Nov 2024
    The WS55-180 was defect. A replacement solved the problem.
  1. WS55-220 BLDC Driver Mains Connection
    By ajayre in forum CNC Machine Related Electronics
    Last Post: 08-11-2018, 04:43 PM
  2. re groups in cam V29
    By woffler in forum BobCad-Cam
    Last Post: 02-23-2017, 01:41 AM
  3. X4 Blinking When Turned On
    By dpaish in forum Syil Products
    Last Post: 10-26-2012, 05:42 AM
  4. Pro E 'blinking' problem
    By John@CRDM in forum PTC Pro/Manufacture
    Last Post: 03-05-2009, 12:21 PM
