589,273 active members*
6,054 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > WTB Timing pulley: 151mm diameter or somewhat close AT10, T8, T5
    May 2017
    36
    I recently completed a CNC conversion of the knee on my mill. I 3D printed the timing pulleys and it's all working however I don't expect the 3D printed pulleys to last so I'm looking for either aluminum or steel to replace what I have.
    Focus of this ad is for the large pulley and the larger the better but no larger than 151mm in diameter, which works out as follows:
    AT10, 48 Teeth
    T8, 59 Teeth
    T5, 96 Teeth
    Prefer 20mm or wider
    When I have sourced the large pulley, finding a suitable matching smaller pulley will be less of a challenge.
    So if you have something surplus from a project please let me know
    May 2017
    36
    Re: WTB Timing pulley: 151mm diameter or somewhat close AT10, T8, T5
    I found what I was looking for, if anyone needs a 48 tooth AT10 gear for a project I will have a spare.
  1. Timing pulley cutting!
    By Memran in forum Benchtop Machines
    Last Post: 09-04-2012, 01:21 AM
  2. bridgeport timing pulley
    By dgalaxy in forum Bridgeport / Hardinge Mills
    Last Post: 02-19-2008, 10:41 AM
  3. Can't find a timing pulley
    By chevdrgtrk in forum Uncategorised MetalWorking Machines
    Last Post: 07-31-2007, 06:15 PM
  4. Timing Pulley Question
    By SPEEDRE in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2006, 04:46 PM
  5. Timing pulley question
    By pstockley in forum Mechanical Calculations/Engineering Design
    Last Post: 04-21-2006, 07:35 PM
