Hello!
We have a new retrofitted 3-axis CNC Milling Machine that uses a China-made breakout board for Mach 3. Everything's running smoothly as planned but here's the problem:
We have calibrated the steps per unit of my X and Y axis including backlash with a dial gauge so I guess it is right. However, when we try to run a simple program to test the machine, the product seems to have the wrong dimensions.
Example: A mild steel plate with a slot hole in the middle. The slot dimension is 10 mm wide x 50 mm length. I programmed it in Mastercam and then ran it. When the job finishes, the slot dimension goes from 10 x 50 to 9 x 48.
Any idea why this is happening?
I appreciate any help you can provide.
-Jerico
