589,388 active members*
6,877 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > X and Y axis not moving as commanded.
Results 1 to 7 of 7
    Dec 2017
    17
    I am having a bit of an issue with my CNC and will need help to diagnose and troubleshoot the issue. I am using stepperonline T6 servo on my X and Y and I have computed the steps per unit to 1000. I have measured backlash to be 0.01mm on both X and Y. When I issue a command for the machine to move 270mm, it always move 269.75mm consistently. For a move of 200mm, it moves 199.98mm. This issue is persistent on both my X and Y. The annoying thing is that the errors are not linear. Initially, I thought the servos were not properly tuned so I did the same test on the X axis but with a closed loop stepper motor and the machined moved 269.60mm instead of 270mm. I am using cncdrive AXBB-E. I have checked all the ball screws for binding and misalignment and everything looks fine.
    https://www.cnczone.com/forums/attac...d=506042&stc=1
    Apr 2004
    5770
    Re: X and Y axis not moving as commanded.
    Are you applying backlash compensation? That can have somewhat random results.
    Andrew Werby
    Website
    Dec 2017
    17
    I do not have backlash compensation enabled.
    Apr 2004
    5770
    Are these values that are appearing in your DROs, or are they measured? They don't seem to be consistent, so I'm suspecting "thread drunkenness" in your screws. Unless you're using expensive ground ball screws, some errors are to be expected, and are worse in the cheaper grades. Another thing that can cause this is loose mounting of the screws. Put a dial indicator on the stage experiencing errors, and see if it's possible to change the reading by pushing or pulling on it.
    Andrew Werby
    Website
    Jan 2024
    6
    Examine the mechanical components further. Although you've checked for binding and misalignment of the ball screws, there could still be other subtle issues within the machine's structure that might affect the movement accuracy.
    Dec 2017
    17
    Those are values measured with a digital caliper. My ball screw is "fairly" straight with about 0.2mm bend in the middle.
    Apr 2024
    23
    I'm having the same problem kind of but haven't even started yet lol. I've been researching this video though.
    https://www.youtube.com/watch?v=TJDbKQzKXYc
    Jun 2024
    Dec 2017
    17
    I fixed my issue by having the ball screws replaced. Everything looks good now.
  1. Replies: 14
    Last Post: 05-26-2022, 02:14 AM
  2. Mach4 Axis 0 Commanded While Disable Help
    By Biggermens in forum Mach Software (ArtSoft software)
    Last Post: 12-05-2018, 06:16 AM
  3. Z axis is not stopping at commanded position
    By amitkumar171 in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-19-2018, 08:43 PM
  4. Alarm: commanded X-axis move too far positive
    By JonMatear in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2008, 02:41 PM
  5. parser: commanded z axis move to far possitive
    By tonymann in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 06:05 AM
