585,931 active members*
5,572 visitors online*
Thread: X axis code
    X axis code
    Hi I have a Syntec controller and I am getting a error on the x axis 21.1
    But the x axis is not moving it is moving in Y so I think there is a connection issue?
    Re: X axis code
    when you press Y axis key ,check if X axis moving . if press Y ,X axis moving ,check the single cable connection etc .
    Re: X axis code
    we found a bare wire grounding out sorry I dont get on here to much to update
  1. Replies: 1
    Last Post: 11-07-2019, 06:18 PM
  2. DMS 3 Axis Gantry run 5 Axis code?
    By R-Vogel in forum Milling
    Last Post: 10-25-2019, 10:23 PM
  3. B Axis Does Not Appear in G code
    By sarsali in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-05-2019, 06:39 AM
  4. Replies: 14
    Last Post: 07-19-2014, 05:55 AM
  5. G code help C-X axis
    By slkret in forum G-Code Programing
    Last Post: 05-10-2008, 02:53 PM
