567,394 active members*
3,359 visitors online*
    Apr 2011
    5
    Question XC609M SETUP OF AXIS MOVEMENT
    Hello all
    Im trying to set the distance parameter a axis will move but when i add decimal point to number it doesn't enter goes to single number.
    So has anyone experience in setting these up ?
    https://youtube.com/shorts/NSwxFMO2NxI?feature=share
    look here for vid
    Apr 2011
    5
    Re: XC609M SETUP OF AXIS MOVEMENT
    Jan 2009
    103
    It has to be a number between 1 to 999999999, no decimals because it's a motor pulse count.
    Apr 2011
    5
    also same issue with next line axis rotation
