548,681 active members*
2,140 visitors online*
    Jun 2016
    Xilog plus error
    Hello,
    Machine model TECH99L ESA K6
    s/n AL104042
    1. I run PanelMac (Xilog Plus) on the PC, when the programm boots up,I get this error code
    Except [24,6]- NCI(1-6) : Reading an invalid item
    (see pic_1)
    2. Clik <OK> on Messages error window and get Automatic mode, and get Alarm CN1012 : ? ( see pic_2)
    3. Click on menu item Calibration, machine run and after finish I get pic_3
    4. Click on menu item MDI , I get this error code
    Except [25,5]-NCI(14-6) : Communication failure with CNC !
    (see pic_4)
    Can You help me ? Any suggestion ?
    Attached Thumbnails Attached Thumbnails pic_1.jpg   pic_2.jpg   pic_3.jpg   pic_4.jpg
    Mar 2003
    35476
    Re: Xilog plus error
    Call SCM?
    I've never seen that particular error.
    Once in a while I get the "lost connection", and restarting the software always reconnects.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    I HAVE SCM TECH Z2 serial number is AA1/017045
    I get this error code Except [25,5]-NCI(14-6) : Communication failure with CNC ! ON XILOG SOMEONE HELP ME
  1. Xilog 3 error CN25 su lavorazione 3D
    By AmePante in forum Italian
    Last Post: 07-12-2018, 02:57 PM
  2. Xilog+ PC error
    By fringledingle in forum CNC Machining Centers
    Last Post: 02-21-2018, 09:13 PM
  3. Xilog Error
    By GG33 in forum CNC Machining Centers
    Last Post: 08-17-2017, 08:02 PM
