550,190 active members*
2,946 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Y-axis move to the left when press right
Results 1 to 5 of 5
    Dec 2021
    3
    Hello Everyone,
    I have a Chinese CNC cutting machine with a Panasonic servo driver and motor
    Servo driver model: MBDJT2210
    Servo motor Model : MHMJ042P1S
    the Y-axis moves only in the left direction even I move it manually from the control unit when I press the keyboard right key the motor move to the left (and the left key work properly to the left)
    I have changed the control unit and the same problem occurred
    and all the settings on the controller are correct
    please help what is causing this problem
    Jun 2005
    1392
    Re: Y-axis move to the left when press right
    Check which key is programmed to move axis right the right. This is normally programmable
    You could use the MDI screen and issue the following commands
    G1 x1 F20 This should move axis to the right one unit
    G1 x-1 F20. This should move it to the left two units
    If these work it is clearly a key programming issue
    Sep 2015
    5
    What software you have, check if mapping is correct. Or connect x axis controller to y and see if it behave the same. It will help if know what software you are using.
    Dec 2021
    3
    Thank you for your reply
    The key is normally programmed,
    the key is working right to the right sometimes and then suddenly turning to move to the left!!!!
    Dec 2021
    3
    I have tried to connect the X driver to Y and the same occurred!!!
    Quote Originally Posted by ahmedhamdoun View Post
    Share drive and controller pictures
    Nov 2013
    1540
    I suspect that your wiring from the breakout board to the servo drive is somehow faulty. It sounds like the servo drive is NOT getting the correct Direction Signal.
    It may be that you have a pull-up resistor when you require a pull-down resistor or similar.
    Craig
    Hello Everyone,
    There are two ways to correct this:
    1- Change parameter on the CNC controller
    2- Change parameter on the servo driver.
