525,429 active members*
2,299 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Yam ck1 12 station turret, internal boringbar toolholderblock
Results 1 to 10 of 10
    Mar 2020
    7
    I need at least one of these toolholder blocks. Do anybody know where i can found these?
    Mar 2020
    7
    Re: Yam ck1 12 station turret, internal boringbar toolholderblock
    up
    Jul 2017
    4
    dear sir i have the same machine yamck1 with control fanuc 10 t and i have a problem with the parameter can u help me
    Mar 2020
    7
    I can try.. what kind of problem?
    Jul 2017
    4
    the parameter no 9108 in my machine is 11100000 but this make measure key is not working for measure tool offset geometry so i want to know the parameter no 9108 right one
    Mar 2020
    7
    Are you sure that you do it right way? You first write axis what you measure. Z or X and then value and after that push softkey measure? If you write only value and measure, it dont works. I can check parameter in this weekend. I have all parameters in paper.
    Jul 2017
    4
    thank you sir for replaying and its working now i write x0 then push measure and its working and i will be thankful if u send to me ur email or whatsaap to contact with u thak you very much
    Jul 2017
    4
    dear sir i have an error called " non mask interrupt "how can i solved it my machine is yam ck1 control fanuc 10 t
    Moderator
    Dec 2005
    531
    Quote Originally Posted by mohamedmo2nes View Post
    Please start your own topic, in this case in the Fanuc forum. You're hijacking a "Want to Buy" topic.
    Mar 2020
    7
    Up!
  1. Replies: 3
    Last Post: 05-13-2020, 10:44 PM
  2. Replies: 22
    Last Post: 06-08-2019, 05:47 AM
  3. Converting my Engine Lathe to an 8-Station Turret Lathe!
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2018, 04:56 PM
  4. Replies: 0
    Last Post: 04-24-2018, 03:37 AM
  5. Replies: 1
    Last Post: 09-15-2013, 04:07 AM
