524,118 active members*
2,124 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Yasda-Fanuc 15MA Starting Problem
    Question Yasda-Fanuc 15MA Starting Problem
    Hello, my name is Salvador and I am from Mexico, I am new in the forum, I work as a maintenance engineer in a Japanese company.
    I have a problem with Yasda YB-850V year 1995 Fanuc 15MA control.
    When I turn it on for the first time, the following message appears:
    F15M14
    SYSTE ALARM
    02: 5139: 01: 4045: 0011: 0094H581
    NMI ERROR (00185C): PC040
    After stay on for a while and restart appears the following message:
    M15M14 AA2RA
    ROMTEST: END
    RAM TEST: END
    SUB CPU RAM TEST: END
    SERVO ROM TEST: EDN
    SLOT06 (015C):
    The A16B-2200-0521 BASE0 card has the red LED number three on. (I haven't found the manual, so I don't know what the red LED on means).
    I have removed the card A16B-2200-0521 BASE0 and I suppose that the parameters have been erased, although before removing it I already had the previous message.
    I have tried to send the parameters again but when pressing keys 7 and 9 the machine does nothing and gives me no option.
    In Mexico it is expensive and difficult to get the A16B-2200-0521 BASE0 card, so first I would like to know your opinions.
    I hope you can help me!!!
    Regards!!
    Apr 2009
    1190
    Re: Yasda-Fanuc 15MA Starting Problem
    What is the part # of the BASE0 board?
    I can skype with you for more help.
    I solved the problem.
    1.- The problem was not the Base 0 board
    2.- Slot 6: referred to the RISC CPU board (it was damaged)
    3.- Fanuc quoted the RISC card at 25,000 USD (a lot of money)
    4.- A service company gave me the option to deactivate it (I chganged some parameters)
    5.- I removed the board but machine blocked at the beginning (it was a short circuit in a Relay)(SLC error 84 (00):PC050 alarm)
    6.- I changed Relay, I sent parameters and it worked perfectly.
  1. Fanuc 15MA software? problem
    By manab in forum Fanuc
    Last Post: 05-31-2011, 04:09 AM
  2. Fanuc 15 M - Starting problem
    By rajappa in forum Fanuc
    Last Post: 05-26-2011, 10:32 AM
  3. problem starting up FANUC
    By gisbertz in forum Fanuc
    Last Post: 05-30-2009, 09:14 PM
  4. Makino mc86 with Fanuc 15MA spindle problem
    By vk_rathi in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2009, 09:09 AM
  5. Fanuc 15ma - Kafo milling machine problem!
    By F.Sharifi in forum Fanuc
    Last Post: 06-09-2007, 07:58 PM
