I recently purchased a Yaskawa Servo Motor model number SGMGH-44A2A6B and a Yaskawa Servo Amp model number SGDS-75A12A at an auction. I want to use them in a lathe retrofit project, so I only need to control the direction and speed of the servo motor.
Can you provide recommendations on the motion controller that could take the analog (rheostat and switches) to drive the servo amp and motor?
The servo amp is oversized quite a bit, so if I could find a third party driver that would be better suited for the project and drive the 4.4 kw motor, I would make that work as well.
thanks,
jdub
