Originally Posted by
gunmaker
Posted over on the Milltronics section as well.
Well I finally got the 4th axis running. However when I tell it to spin 180 degrees it spins all the way around. Not sure which setting I need to change.
I got a Yaskawa servo drive parameter list from Milltronics after many messages back and forth. As well as a rotary setup sheet to change a few control parameters.
I also want to figure out where the little homing program is that tells the machine how far to go after finding the home switch . Well, mine is now a prox sensor I had to figure out how to wire up using the prox sensor triggering a relay to mimic the home switch wiring diagram. Thank God for YouTube. I can move the little home block inside the 4th axis, but that's only a rough setting. I would like to find out how to get it homed exactly where I want it.
The final drive motor to table on this Tanshing VRNC-210 is 90:1
Here's a list of parameters I changed on the servo drive and control.
FileType,User Parameters Data File
Made-by,SigmaWin200 Ver1.13
DateTime,2007/06/01 07:41:20
SERVO-TYPE,SGDH-10AE
UserPrm,000,1
UserPrm,001,0
UserPrm,100,50
UserPrm,101,650
UserPrm,103,165
UserPrm,104,40
UserPrm,10B,0
UserPrm,10F,0
UserPrm,200,0
UserPrm,202,4
UserPrm,203,1
UserPrm,207,0
UserPrm,300,184
UserPrm,401,100
UserPrm,402,800
UserPrm,403,800
UserPrm,406,800
UserPrm,407,10000
UserPrm,409,350
UserPrm,500,7
UserPrm,504,7
Control parameters changed:
PPU 1000
Axis address label 65
Home Sequence 2
Positive Limit 50000
Negative Limit -50000
Maximum Feed 5000
Rapid Velocity 6000
Fast Jog Velocity 3000
Excess Error 1.75
Max HDW Error 1.0
Proportional Gain Same as X&Y
I can't imagine what a pain in the ass this would have been had I used a DMM servo motor and drive as I originally planned. The time I've spent banging my head against the wall is time I could have spent working on my client's projects. The $100 cable to hook up SigmaWin to the drive was only useful for entering all the parameters as apparently nobody knows how to use it, or is willing to share their dark magic.
