Hi there. I have just got a Yaskawa V1000 and as it can use rs485 decided to have a go at getting it running for more precise control and on screen feedback.
To be clear I have absolutely no idea what I'm doing, it's been a bit of a make it up as I go along sort of thing.
I started out following two YouTube guides for different inverters (Bosch EFC5610 and Hitachi WJ200) and using their manuals to compare and try and gleam the information I needed to set it up to mine. Where that fell down was I just couldn't figure out the VFD address values to put in the Address ModBus (Var). The manual says things like 0001H and as you will see on the link below I don't see how he came to 2, 36 and 38. I was also unsure about what types of input and output to use as both guides used different types for the same function.
I was also getting a CALL error on the VFD screen and the alarm led flashing up, and still am.
Then I found this guy had run the same VFD and posted his settings, so I copied them exactly and downloaded his brain and screen set.
http://www.cnczone.com/forums/commer...-software.html
I still have the run command configured to digital input, because I could figure out the address value to do it through modbus, and this works ok. Then frequency response to the VFD and current and rpm from the vfd to mach via modbus. None of this works in either direction.
My ModBus Configuration under Function Cfg's looks identical to his. ModBus run says no error on the com port.
I have checked and double checked all the relevant settings in Mach3 including ports and pins and also the parameters in the VFD and they are all correct. Again with the wiring (which is T/R+ to R+ and S+ / T/R- to R- and S- as per the manual) checked and double checked, there is no short between loose strands or anything and is correct. I also tried with S+ and S- disconnected.
I have dip switch S2 set to on but also tried it off just to see if it made a difference.
The baud rate set in mach3, in the com port settings in windows device manager and at the VFD are all matching. In fact I tried two different baud rates - 9600 and 38400.
The USB to serial driver is working ok according to windows device manager on the correct com port and with correct drivers.
I have even tried removing the reverse rotation prevention in the VFD (b1-04) and changing the run command type from FWD/REV to START/STOP in H5-12 and have tried both enabling and disabling RTS control in H5-07 and in Mach3 and every combination between them.
I seem to have no communication between the PC and the VFD via ModBus. The spindle still turns on and runs ok when I change the frequency reference in the VFD to accept analogue instead of serial, and this also removes the CALL error. In fact the CALL error only comes on the VFD when I change either b1-01 (frequency reference) or b1-02 (run command) to accept serial instead of digital/analogue.
So the digital run command works and DRV flashes but the frequency setting via modbus doesn't and there is also no feedback coming from the VFD to the PC.
I bought two different USB-serial converters just in case there were any compatibility or driver issues, but both are fine and I've tried using both to no avail.
I also have the VFD set to remote mode, it works absolutely fine operated by the control panel in local mode as well.
I cannot figure out why it's not working.
