547,049 active members*
2,618 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Z axis drops on power off
    Mar 2008
    619
    Is there a brake on the Z axis head on the mid 2000 Fadals??? I came in from a break and the head was all the way down on the table. Luckily there were no parts and i have no cutter to be destroyed. I have never seen this before and assume the Z servo has a brake. If there is a brake and it's bad... it will have to wait while I finish up some big projects and the temporary brake will be a length of 4 x 4 wood.
    Apr 2014
    333
    Re: Z axis drops on power off
    My extended z axis 2006 does have a brake but most don’t.
    Check inside your column if it does not have a counterweight it will have a brake. There is a little brake controller board in The electric cabinet.
  1. Sometimes the Z axis Drops after power-down
    By pryotex in forum Charter Oak Automation Support Forum
    Last Post: 01-22-2020, 10:30 PM
  2. Z axis drops when power removed
    By ecurb5 in forum Avid CNC
    Last Post: 04-04-2017, 08:15 PM
  3. HT23SII Lathe - X axis drops at power down
    By colton_m in forum Hitachi Seikis
    Last Post: 09-26-2016, 07:01 PM
  4. Need Help Z Axis Drops for No Reason
    By HoosierGunCoat in forum CNC Machining Centers
    Last Post: 11-18-2014, 08:32 PM
