601,789 active members*
2,849 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Z axis falls down when power turned off.
Results 1 to 14 of 14
    Aug 2008
    15
    I just replaced the 4 D Cell batteries on the back of my fanuc robodrill t14ia that were dead upon arrival of my used machine I just purchased. That gave me alarm 300,
    manual refrence position return is needed for the n-axis ( xyz).
    It shows up with alarm 300 for all four axis x,y,z,a.
    My problem is when I turn the controller off the z axis immediately begins to lower until you stop it with your hand, then it stays put.
    Might not be worth mentioning but my garage wasn`t at room temp, the machine was quite cold when I fired it up.
    Thanks.
    Feb 2007
    664
    is there a counter wait in the back of the machine ?
    is it still bolted to the machine ,if it has a counter wait they would bolt it to the machine when moving the machine
    or you could have a "Z" axis break problem , if it has one
    Aug 2008
    15
    No counterweight on the machine, z axis break problem, what is that and how can I check or fix
    Thanks,
    Andrew
    Feb 2007
    664
    most of the time they are on the motor of the axis ,could also be one the screw
    I'm wondering if the machine lost it's parameters when you changed the batters
    Feb 2007
    664
    the break should be on when not powered
    Aug 2008
    15
    I know the parameters were lost because the batteries died in the 12months the machine sat before I bought it used. About the brake, I am curious is it something that can be adjusted or what, and is it typically on the servo motor itself?
    Feb 2007
    664
    most of the time it's on the servo motor ,
    it looks like a clutch , springs hold it closed when not powered , an electric magnet pulls it open when powered
    Feb 2007
    664
    it could have been damaged from shipping , or stopped work before you had the machine
    Aug 2008
    15
    That makes sense then, do you think it's safe to use the machine in the meantime do some test cuts and run the machine until I can afford to take a look at the problem. Or should I dig around the servo motor and see what I can come up with. Unless it's a big job to take it all apart.
    Thanks that does help a lot actually.
    Feb 2007
    664
    if you remove the servo motor make sure you block up "z" axis , or it could crash it to the table
    Jul 2009
    108
    it wouldn't be losing hydralic pressure when powering down? just a thought
    Mar 2009
    100
    Before you take the whole machine to pieces, my FANUC controlled (fanuc servos) has an operator page where I can turn ON and OFF the servo brakes, need to when alligning T1 and T2 axis to home position..
    Might be an on/off issue in the control. Now do I know for a fact this is the same in your machine? Nope-read the manual!!
    Dec 2008
    jpwillard
    On a Haas there is a CO2 bottle that, when stays pressured, keeps the z-axis from falling.
    Apr 2025
    Re: Z axis falls down when power turned off.
    I know this post is quite dated however, did you ever find a resolution as I am having the same issue now… Fanuc Robodrill T14ia
  1. Spindle falls to start.
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 06-17-2008, 01:16 AM
  2. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
  3. Looking for a CNC Machinist - Niagara Falls, NY.
    By Gunner in forum Employment Opportunity
    Last Post: 02-29-2008, 07:40 PM
  4. V2XT motion falls short..
    By Lasershop in forum Bridgeport / Hardinge Mills
    Last Post: 03-16-2007, 05:50 PM
  5. Tooling Falls off Racks?
    By nonnsgranite in forum Material Machining Solutions
    Last Post: 08-02-2006, 08:09 AM
