504,045 active members
4,274 visitors online
IndustryArena Forum > CAM Software > Vectric > Z plunges for no reason!
Page 1 of 2 12
Results 1 to 12 of 15
    Jul 2013
    208
    I’m trying to make a sanding dish that is 22” in diameter and maybe .25 deep
    I’m using a KL1212 router and Mach 3 along with Vetric Aspire.
    I used all the default parameters when I chose a .5” ball nose for the rough cut.
    About 1/5th the way into the cut, the Z plunges and throws everything off kilter.
    Any thoughts?
    Apr 2005
    81
    Re: Z plunges for no reason!
    Which controller you have?
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jul 2013
    208
    I’m using Mach 3
    I have a KL1212 cnc router
    The program i used was Vetric Aspire
    Sep 2005
    1602
    Quote Originally Posted by robwiacek View Post
    I’m using Mach 3
    You asked the same question yesterday?
    Here> https://www.cnczone.com/forums/diy-c...-software.html
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
    Jul 2018
    666
    Hello Rob - Machines do not do anything for no reason. You will have to work through the mechanics of the machine to check everything is OK and you will have to check the program is OK. No simple answer... Peter
    Dec 2003
    336
    Where does the model for the project come from?I would be more concerned about a discontinuity in the surface of the stl file than the machine in the first instance.I only have a little experience using Vectric software for 3D projects and that was Vcarve rather than Aspire so I might be missing something on that side,but given that the machine has worked previously,why would it start to misbehave now?Did nothing show up on the animation of the cut?I would run the simulation again at the highest resolution and look closely at the problem zone to see if a sudden plunge is apparent before attempting to diagnose a machine problem that might not exist.
    Sep 2005
    1602
    Run the simulation and run it at slow speed, if its not showing in that or the final results its a mechanical/electrical issue with your machine.
    Jul 2013
    208
    I created the dish in Vetric Aspire.
    I set the parameters and used default settings for the .5 ball mill.
    I’m going to add a picture shortly.
    Jul 2013
    208
    BTW, nothing showed up in the simulation. It was a clean run.
    The fact that it happened twice worries me.
    Check out the cut. There’s a dot that indicates where it plunged and a deep cut along the x axis after the PRZ was rearranged
    Jul 2013
    208
    This is a second try showing a similar result.
    There are other screw holes thT don’t have anything to do with it, but the Z plunge us there along with that wacky X axis run
    Sep 2005
    1602
    Once again you have machine or electrical issues.
    Apr 2005
    81
    Electrical noise would be the culprit No1, IMHO.
Page 1 of 2 12
  1. G76 Threading plunges straight to full depth???
    By bradlar90 in forum G-Code Programing
    Last Post: 08-06-2016, 01:07 PM
  2. Plunges are being blended
    By giffpa in forum Tormach PathPilot™
    Last Post: 08-20-2015, 01:53 AM
  3. TB6560 controller Spindle ON on power up OFF Mach3 Plunges
    By Roy50 in forum Mach Software (ArtSoft software)
    Last Post: 10-03-2014, 08:32 PM
  4. Is there anyway to control where plunges occur?
    By John Coloccia in forum MadCAM
    Last Post: 02-24-2014, 04:39 PM
  5. NC code posted and Z plunges deep into workpeice on MDX 500
    By ducatidragon916 in forum Mastercam
    Last Post: 09-25-2013, 02:20 AM
