585,930 active members*
3,281 visitors online*
Login Register
René Gerber AG  - Banner
René Gerber AG
News
Swiss precision in deburring, honing and polishing
2019-09-11 Drill bits in focus: Perfect cutting edgesincrease the service life
The long-life formula for drill bit cutting edges is a specialist area of René Gerber AG, who impose the demands on themselves to im-prove continually in this field and to take the reputation of the spe-cialist into account. Go to press info
2019-09-04 For the perfect cut - edge honing of cutting tools
For us, a good cut in the case of cutting tools is not good enough - it has to be perfect! Precise edge honing for cutting tools not only gives an excellent cutting result, but also increases the service life of the cutting edge. Go to press info
2019-08-20 An all-round success: expert deburring and honing of rotors and stators
Sometimes a sintered part appears to be finished - but you are not satisfied with the result. Something is missing. The final touch so to speak. We have the solution for perfect deburring and honing of the edges, so that your sintered part gets rounded off. Go to press info
2019-07-24 Extending the service life of punches and dies
Marc Schori, CEO of René Gerber AG, in an interview with Dr. An-dreas Feuerhack, WZL - Laboratory for Machine Tools of RWTH Aachen University. Dr. Feuerhack has been working at WZL since 2014 and supervised the areas of fineblanking and stamping from the start. He now oversees the industrial research in the field of forming and the research group for fineblanking. Go to press info
2019-07-19 The solution without any rough edges: Deburring valve plates
Individuality has always had rough edges. Be that as it may. But from a technical viewpoint, the René Gerber AG Company prefers to focus on better production planning through reliable functionality of the components rather than on an individual with rough edges. Go to press info
2019-07-19 Efficient and reproducible honing of threading inserts
Customers are accustomed to the accuracy and extreme precision of René Gerber AG, based in Lyss, Switzerland. For years, the company has been a specialist in the field of honing cutting tools made of carbide. Go to press info
