Hello Bill,
There was a batch of pcbmade in Germany. I believe it to be around 400 pieces but it was a closed deal. This means that you had to order and pay in advance and that the number of pcb's equals the ordered number so there are probably none left.
However. If you're an electronics vet you should have no problems getting yourself a pcb. A highres layout (pdf print at 100%) is available so making a film (or toner transfer as I do) pcb is a breeze. The available PCB layout is exactly what was ordered bet the pro boards also had a silk screen, which again is easy to duplicaty using toner transfer and the parts layout pdf.
Best regards,
Erik Jan
What goes down, should come up.
