585,919 active members*
3,736 visitors online*
Login Register
HEIDENHAIN Forum
Open Source Controller Boards > New board help requested - Page 2
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Jun 2003
    3312
    vladdy,
    Just sketching it out, listing attached, haven't checked it against pin numbers, and half stepping. Really forming ideas for a basic start.
    Phil
    Free smal Basic compilier for AVR's:
    http://www.mcselec.com/bascom-avr.htm
    Attached Files Attached Files
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  2. #22
    Sep 2005
    AVR project status?
    Phil,
    Are you still working on this project?
    I'm interesting in learning microcontroller too.
    I had coded something similar to yours but on an AT90S8515 (coded in assembler). I was able to simulated it on the STK500.
    Please let me know how this project goes.
  3. #23
    Jun 2003
    3312
    Kind of,
    I sent a blank board to Ito Brazil (cnc zone handle) a couple of weeks ago. I actually in the last couple of days have started looking at it. I had stolen the FET's for the L297uniboard prototype and ordered a different Mosfet for this avr board which I now have, I'm looking at the half step code also. Will keep you posted.
  4. #24
    May 2004
    200
    hows this Going Phill? Im looking for some drivers that can run @ 55V dc. I like the DYI world.
    thanks
  5. #25
    Mar 2004
    75
    Wink H bridge drivers for bipolar steppers
    Look at the IR2010 H bridge drivers.
    They can drive most FETs
    Voltages to 200 volts
    Directly interface to microcomputers
    Can be bootstrapped so no high voltage supply source is needed.
    http://pdf.alldatasheet.co.kr/datash...RF/IR2010.html
    There are a number of other H bridge drivers with similar performance
    Add current chopping and you have a high current - high voltage bi-polar driver.
  6. #26
    Jun 2003
    3312
    Hi guys,
    Teckno,
    Actually I'm in work on a expanded version of the AVR board on the first post. 100V, unipolar, heavy current (can't say yet, the FETS are more capable than the board will be) microstepping. The unipolar will come first as the hardware is almost ready to order protoboards on. Microstepping has been the hurdle to implement in a low cost, KISS design, but that too I believe is not an issue, at least to 1/8th step.
    Also in parallel is a bipolar design.
    BCwandererer, I'm familiar with the 2010, 2104, etc. Right now I'm playing with P channels on the top side though. Their simpler, their cost too implement is less, 120V 14A Pchannels don't cost much these days and their pretty robust.
    Both designs are limited to 100V.
  7. #27
    Mar 2004
    75
    Unipolar microstepper design
    I would like to contribute some ideas for a unipolar, pic18252 based design.
    I have been working on the board design.
    I have not started coding as I have been working on the layout.
    The microproccesser is a pic18252 because I have some on hand.
    Resonator is 20 mhz
    I am driving the FETs with a high current driver chip.
    Microstepping will be by using a resistor ladder with 4 micro outputs to input into the comparator that controls the current in each leg.
    The board layout is still under review as there may be some bypass caps to add. Values of resistors on the layout are not right. They will be fine tuned when calulated.
    When the unipolar unit is working, a bipolar unit will use similar coding.
    I am throwing it out for ideas.
    Maybe someone has done this before and has ideas that will shorten the learning curve.
    Layout and schematic attached (forgive the non-technical layouts - I am still new at this)
    Schematic reloaded in larger size
    Attached Thumbnails Attached Thumbnails Unipolar stepper driver board.jpg   Unipolar stepper driver.jpg
  8. #28
    Jun 2003
    3312
    BCwanderer,
    I can't read your schematic can you enlarge it?
  9. #29
    May 2004
    200
    Sweet. are you planiing on a chopper board or resisters? and or are you going to expand this to Bipolar.
    Sorry I havent replyed just been a lerker of late.
    Tek
    Quote Originally Posted by pminmo
    Hi guys,
    Teckno,
  10. #30
    Jun 2003
    3312
    tekno,
    if the question is to me, they are chopped.
  11. #31
    May 2004
    200
    THanks Phil it was to you.. sounds like a sweet idea. I have been thinking of how to make a Power Supply since I read this.
    tekno,
  12. #32
    Dec 2007
    HI, very new to this cnc idea but would like to know if anyone has built a controler ussing the Alegro a3983 driver chip, if so do you have a circuit diagram and board layout and how did you cope with the heat disipation. I was thinking of mounting it upside down and gluing or soldering a heat sink to it.
  13. #33
    Sep 2008
    3
    Can't Believe AVR on cnczone forum...
    I just bought the Butterfly proto board about a month ago with the c programming manual kit. Thought about doing a cnc system with it . I joined the forum and being a linux user went right to the open source after introducing myself... Was wondering where this section of the forum was heading and if AVR Butterfly could be of help... They are cheap and I am thinking about buying em for christmas gifts.
Page 2 of 2 12
  1. hobbycnc board
    By wjbzone in forum CNC Machine Related Electronics
    Last Post: 09-08-2012, 05:07 PM
  2. single sided A3977 board ( got files uploaded )
    By tekno in forum Open Source Controller Boards
    Last Post: 01-28-2007, 02:30 AM
  3. New and need your help Please (driver board)
    By Oldmanandhistoy in forum CNC Machine Related Electronics
    Last Post: 06-12-2005, 10:48 PM
  4. Mach2 & Rutex relay board.
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2004, 07:50 PM
  5. Scanner board info
    By Jan in forum CNC Machine Related Electronics
    Last Post: 12-08-2003, 09:26 PM
