585,977 active members*
3,756 visitors online*
Login Register
INDEX-Werke // INDEX TRAUB Forum
PlasmaCam > G92 Error
Thread: G92 Error
Results 1 to 5 of 5
    Dec 2019
    G92 Error
    Can anyone help me about what to do when the machine keep whrithing Error G92 every time i try to run the contour?
    It is brand new portable cnc plasma cutter from Huxia cnc in China, but when i whrithe to them they do not answer, they have not done that since payment.
    The controller is a starfire, and the only thing i can find about G92 is this
    (COPY (1) G92 reference point setting Set program is running, processing starting point (reference point) coordinates, must start in the program, and set the absolute coordinates. Format: G92 XnYn If not after G92 with X, Y, with the current X, Y coordinates of reference points. In commonly when used machine tool positioning, G92 not with X, Z content.
    It do not help me what to do. I have tryed to zerro all coordinates it make no difference, i have succeesfull been running a outline ( square around the part to see if it is on the sheet)
    Aug 2009
    1573
    Re: G92 Error
    Feb 2021
    Re: G92 Error
    Our specialist team provides a 24/7 emergency Residential locksmith Houston service. An unexpected break-in is a distressing time and leaves your house even more vulnerable, thus we aim to maintain your premises within half an hour of your first call. Your safety is a priority for Locksmith in Houston; regardless of what scenario you’re stuck at, our specialists are ready to help you at every hour of the afternoon for an inexpensive price.
    https://magnetlocksmith.com/commercial-locksmith/
    May 2022
    3
    Re: G92 Error
    In case you are looking for a really good locksmith service you have to try hounslow locksmith. London's most trusted and affordable mobile locksmith.
    15362
    Re: G92 Error
    Quote Originally Posted by cjbjerringbro View Post
    Why are you using a G92, it's not normally needed, G54 will do what you need, it also may be faulting because the way it is being used, (a G92 command shifts all work coordinate systems (G54-G59) this is kind of how it works.
    O60921 (G92 SHIFT WORK OFFSETS) ;
    (G54 X0 Y0 Z0 is at the center of travel) ;
    G00 G90 G54 X0 Y0 (Rapid to G54 origin) ;
    G92 X2. Y2. (Shifts current G54) ;
    G92 X-2. Y-2. (Shifts current G54 back to original) ;
    M30 (End program) ;
    Mactec54
