531,753 active members*
3,476 visitors online*
Login Register
Mitsubishi Electric News
Changes for the Better
Plug & Play robots for machine tools increase competitiveness
Hanover, Germany, 16th – 21st September 2019
Faster time to market and increased production flexibility can be achieved using Mitsubishi Electric’s M8 Series CNC controllers with Direct Robot Control (DRC) functionality. Both the large touchscreen M800 and the M80 models offer DRC as standard. It allows machine tool operators to program and use robots quickly, direct from the CNC panel without specialist robot programming expertise.
The easy integration of robots for loading and unloading, or secondary operations such as marking parts has the potential to deliver significant benefits to commercial machining operations. Mitsubishi Electric robots and models from KUKA will work seamlessly with DRC enabled controllers from Mitsubishi Electric. The CNC controller and robot are connected using high-speed Ethernet, which allows fast, convenient Plug & Play integration.
The other major benefits of on-CNC robot control are cost savings; a separate robot control unit no longer has to be purchased for example. Furthermore, robot specialists aren’t needed to alter less complex actions, as the operators can make changes to robot functions themselves by programming in G-code via the CNC.
Mitsubishi Electric is one of the top three CNC manufacturers, serving many of the world’s most successful machine tool companies, so these solutions are likely to appear soon on many shop floors. Manufacturers and machine tool operators will both benefit from robots being used for repetitive tasks on shorter production runs. More flexible operation and higher production volumes lead to improved competitiveness and the opportunity for increased profit.
More information
https://www.mitsubishi-cnc.de/further-solutions.html
CNC and factory automation solutions from Mitsubishi Electric at EMO 2019 are located at: Hall 9 / D40.
Wire cutting and die sinking EDM machines from Mitsubishi Electric are located at: Hall 13 / B92.
Mitsubishi Electric
The image(s) distributed with this press release are for Editorial use only and are subject to copyright. The image(s) may only be used to accompany the press release mentioned here, no other use is permitted.
Press contact:
Mitsubishi Electric Europe B.V.
Factory Automation EMEA - CNC
Frederik Gesthuysen
Marketing Manager
Mitsubishi-Electric-Platz 1
40882 Ratingen, Germany
Tel.:     +49-(0)2102-486 4390
Fax:    +49 2102 486 7780
Frederik.Gesthuysen@meg.mee.com
PR agency:
DMA Europa Ltd.
Philip Howe
Europa Building, Arthur Drive, Hoo Farm Industrial Estate, Kidderminster, Worcestershire, UK
Tel.:    +44 (0)1562 751436
philip@dmaeuropa.com
www.dmaeuropa.com
Responsible for the content of this press release: Mitsubishi Electric Europe B.V.
Contact
40882 Ratingen
Germany
+49 2102 486 5000
+49 2102 486 5910
Route planner
Route planner
