508,439 active members
3,448 visitors online
Login Register
Nicolás Correa Service, S.A. Blog
Do you know what scraping adjustment is and what is it for? NC Service shows you in this example.
August 2018
22
Author: NC Service
Company: Nicolás Correa Service, S.A.
The scraping process is an adjustment, manually carried out by means of a tool called “scraper”, which aim is to adapt two flat or curved parts for them to slide each other with the most perfect contact possible. This is a very delicate and important process in the refurbishment of a milling machine since during its use, the constant movement of axes and other elements produces a damage that eventually may cause machining problems.
In the particular case of guides’ saddles wear in each axis (X,Y,Z), this adjustment process carried out during the retrofitting of a milling machine, becomes an essential work bound to prevent possible plays that may affect the accuracy of the machine. Thus, during the refurbishing phase, the grinding of guides’ saddles of all structural elements is performed in first place, seeking a surface as flat and uniform as possible in each one of them. However, performing a manual scraping of all these elements becomes necessary in order to obtain their total adjustment and to assure that all axes meet geometry. The main purpose of this manual scraping of two pieces that have to slide together is, on one hand, to ensure a perfect sliding and adjustment necessary for each function. On the other hand, making small cracks so that the oil could flow through these two pieces in continuous friction will prevent them from being completely smooth and end up seizing.
To carry out this scraping process, the surface where the piece to adjust slides is painted with a fluid paste (Prussian blue) by NC Service’s experienced technicians. This paste is ideal to check adjustments of moulds and dies, among others, and marks the irregularities of the surfaces with a micrometric thin layer. The parts are assembled in the milling machine to make them slide together, and after dismantling, the paint remaining on the surface of the part to be adjusted will mark those areas with the greatest friction. This will allow the technician to determine the need for adjustment and, if necessary, will show him where to make it, focusing in the most prominent areas marked in blue. If these parts have a uniform contact, except in the oil drain zone, and allows displacement, then we can say that they are well adjusted.
In this video we show you the scraping and adjust the Z-axis iron plate at NC Service.
Blog Archiv
November 2019
October 2019
September 2019
August 2019
July 2019
June 2019
May 2019
April 2019
March 2019
February 2019
January 2019
December 2018
November 2018
October 2018
September 2018
August 2018
July 2018
June 2018
May 2018
April 2018
March 2018
February 2018
January 2018
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
February 2017
January 2017
January 1970
