508,437 active members
3,590 visitors online
Login Register
Nicolás Correa Service, S.A. Blog
NC Service shows the refurbishment process of a CORREA CF17D. Do you want to see the video?
September 2017
26
Author: NC Service
Company: Nicolás Correa Service, S.A.
This is a bed type CORREA CF17D milling machine, manufactured in 2001, with a Heidenhain TNC-426 control unit and an universal milling head. Longitudinal axis traverse of 2000 mm and 800 mm on both the Y and Z axes.
It was fully mechanically refurbished by NC Service at its facilities with initial disassembling of main components. After this, cleaning, sanding, priming and painting were carried on. In the meantime, motors, drivers, power cabinet and CNC were inspected, as well as grinding and adjusting of the three axis of the machine (X, Y, Z).
The milling head was also thoroughly retrofitted by NC Service, with full dismantling and revision of elements, changing bearings and rectifying the principal axis. This is one of the main elements from a milling machine which most suffers during its useful life, so for this component this reconstruction process is of special importance. Requested by final customer, a coolant through spindle system of 17 bar was also installed in this milling head, including new deposit and coolant pump.
As usually, after this refurbishing process, geometry protocols established by manufacturer were carried on in order to certified its mechanical accuracy.
And finally, installation and commissioning were done at customer’s facilities.
This refurbishment process and final result could be seen at the following video.
0 comments
Blog Archiv
November 2019
October 2019
September 2019
August 2019
July 2019
June 2019
May 2019
April 2019
March 2019
February 2019
January 2019
December 2018
November 2018
October 2018
September 2018
August 2018
July 2018
June 2018
May 2018
April 2018
March 2018
February 2018
January 2018
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
February 2017
January 2017
January 1970
