504,555 active members
4,541 visitors online
Login Register
Nicolás Correa Service, S.A. Blog
The geometry of a milling machine refurbished by Nicolás Correa Service
December 2018
11
Author: Nicolás Correa Team
Company: Nicolás Correa Service, S.A.
At Nicolás Correa Service, one of the most important steps during our process of refurbished second-hand CNC milling machines is the one of "putting the machine in geometry". For such purpose, the deviations from perpendicularity between all milling machine’s axes are analysed and corrected to have tolerance values less than 0.02 mm. The straightness of the movement in all the axes and the alignment of all its elements with respect to the ideal axis of operation are also checked.
In the specific case of a bed type milling machine with friction guidance, a dial gauge with a contact point in the end that indicates the deviation of each element to analyse. After achieving the levelling of the bed, two axes are measured by anchoring the magnetic base of the dial gauge in the already aligned axis and the contact point on the rectified piece placed on the axis to be analysed. After the indicator is set to zero, one axis is moved and the magnitude of the error between both axes is checked by observing the movement of the indicator and its deviation from the zero position. When the axes are not perfectly aligned, we carry out a manual adjustment by scraper of the guiding elements and the tightening of the lateral wedges of each axis, carrying out this process repeatedly until the dial gauge indicates both axes are in geometry with a tolerance less than 0.02 mm.
This manual adjustment is fundamental in our milling machine refurbishment process, as it ensures that the geometry of the refurbished milling machine is in adequate levels of tolerance so that the customer can perform excellent and high-precision machining.
Blog Archiv
September 2019
August 2019
July 2019
June 2019
May 2019
April 2019
March 2019
February 2019
January 2019
December 2018
November 2018
October 2018
September 2018
August 2018
July 2018
June 2018
May 2018
April 2018
March 2018
February 2018
January 2018
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
February 2017
January 2017
January 1970
